JGoode
Object placed at a set height???
I was wondering if there is any way that I can script an object to be placed at a set height??
Thanks
ArchiCAD 27
Windows 10
3 Replies 3
JGoode wrote:
Thanks
! 3D_script
CONSTANT_H=0.5 ! Set constant level=0.5m
ABS_Z=-1 ! COEF. In order not to depend on the level placement.
ADDZ ABS_Z*SYMB_POS_Z+CONSTANT_H
BLOCK A, B, ZZYZX
DEL 1
JGoode
SL_GDL wrote:
! 3D_script
BLOCK A, B, ZZYZX
DEL 1
Thanks for the answer but I get an issue with the hotspots not being where they should be so if you could help with that it would be much appreciated.
ArchiCAD 27
Windows 10
The hotspots will need to be scripted between the ADDz and DEL lines so they move with the BLOCK.
