Oval Window from AC15 library -> error
Hi All,
First of all, i'm using the dutch archicad 15 library.
When i use the Oval Window, there is a problem with the window-object when i use a reveal. When i don't use a reveal then the window is drawn perfectly.
On the picture below, you can see that the distance between the masonry and the window isn't the same for left-right en down-up. The reveal is the same (you even can't put in different values).
[/img]http://imageshack.us/photo/my-images/193/screenshot20120809at162.png/[img]
Does this problem also exist in US libraries?
thank you.
[/img]
1 Reply 1
As far as i can tell, the AC15 US version of the window doesn't have this problem.
Scott Graham, AIA LEED BD+C
Principal | BIM Manager
Muhlenberg Greene Architects, Ltd.
Wyomissing, PA 19610
V6.5-26.0
