Overlay Interface images
JGoode
is it possible to overlay interface images so that they can change depending on parameters selected?
Thanks
ArchiCAD 27
Windows 10
1 REPLY 1
Generally no ;(
Depends on what overlay over what... normally no...
if text item has to be over image...it may be possible with
ui_outfield...
ui_picture...
ui_outfield (the same for the second time)
sometimes works sometimes not.
The more frustrating part is that the slicing does not work (when UI is scaled... if scaled 100% it may differ)
because the images get "white frame"...
Piotr
