Own objects
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2013-04-11 04:23 PM
2013-04-11
04:23 PM
I know you can save your own custom objects by File -> Libraries -> Save selection....
BUT it only saves the object in this project if i open a new project (new archicad) then there is just the embedded library and no objects in it what i have made. Do i have to save them some other place to be able to use objects what i have made in other projects to?
I have ArchiCAD 16 SE
Also how can i add my own materials/colors into it. And how can i get m2 of an slab when im using like 10 different sizes of slabs how can i get m2 of each one of them.
Thank you.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2013-04-12 04:06 AM
2013-04-12
04:06 AM
When saving your object you will have the option to save in a selected folder.
If you have already saved in the embedded library you can open the Library Manager and export the selected objects into a folder on your system.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2013-04-12 03:32 PM
2013-04-12
03:32 PM
veljo001:
In addition to Barry's advice, embedded library parts can be exported: open the Library Manager, open the Embedded Library folder, select the part(s) to export, then click the Export embedded subtree into local folder button (looks like a floppy disk).
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
