‎2008-04-08 11:46 PM
‎2008-04-09 04:52 AM
‎2008-04-09 03:15 PM
‎2008-04-09 05:35 PM
‎2008-04-09 05:54 PM
‎2008-04-09 07:02 PM
Douglas wrote:This syntax is wrong:
Hello James :
Thank you for your reply.
However, I don't entirely understand your point.
POLY2_A 5, "Empty Fill", 6,
In that bit you're missing a comma at the end of the first line. "Not enough parameters", the only error I got, can be caused by missing commas. I tested it with the comma and it works.FILL "Solid Fill" POLY2_A 5, 3, 3 0, 0, 1, maxWidth, 0, 1, maxWidth, length, 1, 0, length, 1, 0, 0, -1
‎2008-04-09 07:07 PM
James wrote:Another trick is to do a select-all on the text. Bumpy empty lines are a clue; delete them. (Though the pic is a spacebar-simulation of the effect.)
invisible nonsense
‎2008-04-11 04:17 AM
