Polygon Editing For Slabular Objects
mest79
Hi!
I'm looking for a way to modify object and found this interesting link
http://www.onland.info/archives/2008/03/polygon_editing_for_slabular_objects.php
In 3D thats ok but I have problem in the plan 2D. How can I do?
Thanks!
Michele
Architect
AC22 (3006) - i7-6820HQ, 16Gb, AMD FirePRO W5130, WIN10
1 REPLY 1
Unfortunately Solid Element Operations do not show in plan.
You could show the slab in plan rather than the object - this will give the outline shape.
Or you could convert your object to a morph but you will lose all object parameters and the SEO slab will no longer be needed.
It may be harder to edit as a morph though if you need to make further changes.
So it is a good idea to keep a copy of the original object and SEO slab in a hidden layer for further editing.
