Populate a Text parameter with DIM
JGoode
Is it possible to populate a text parameter with values from DIM ...[ ]?
Thanks
ArchiCAD 27
Windows 10
Jochen Suehlo
Yes, why not. Could you please specify your question?
Jochen Suehlo . AC12-29 . MAC OSX 14.4 . WIN11
GDL object creation: b-prisma.de
JGoode
I'd like to populate it with an autotext array
ArchiCAD 27
Windows 10
Jochen Suehlo
If you mean ArchiCAD autotext: you cannot do any GDL-operation with autotext. You can only use autotext as variable value, parameter value and e.g. in a TEXT2 command as the text value.
But you can use the autotext values in arrays as well, e.g.
DIM q[]
q[1] = "<Landkreis>"
TEXT2 0, -3, q[1]
Autotext must be in angle brackets and quotation marks if variable.
