Problem with object library after upgrade to Arc 25
Fredrik Eng
After upgrade to arc 25 the library doesn´t contain so many objects as before Arc 23
Try to load objet library from arc 23 and consolidate but I still don´t have the earlier object available.  Also tried to load without consolidate but the object doesn´t occur.
There must be a way to solve this.
In 25 you are looking at objects with the 'Equipment' tool.
This will show you only the MEP enabled objects.
Try the regular 'object' (chair icon) tool.
Noemi Balogh
Do you experience this with a specific project or with all of your projects in Archicad 25?
If it's not project specific, try to repair Archicad, it might be possible that not the whole library is available on your computer.
In case of project specific issue, I suggest to migrate project again with its libraries, if you still have the original Archicad 23 project. I believe it should solve the problem. Or, another idea to delete the linked libraries and re-link Archicad 25 library.
Noémi Balogh
Senior Community Expert, Admin
Thank you!!  I´ve missed that icon....
