Problem with "Picture" & "Carpet" V
I'm modelling a museum gallery by Archicad. I should insert lots of different pictures on the walls. But :
I can't change the default image of the "Picture" that is found in the objects Library of the archicad 9. There is no option in its parameter box that allow me to select another image. I have the same problem with the "Carpet". I don't manage to change its defualt pattern into another one. where can I find these images and how can I change them to realize custom pictures and carpets?
Thanks for yuor help. It's really urgent!
3 Replies 3
I can't change the image of the "Picture" that is found in the objects Library of the archicad 9. There is no option in its parameter box that allow me to select another image. I have the same problem with the "Carpet". I don't manage to change its pattern into another one. where can I find these images and how can I change them to realize custom pictures and carpets?
Thanks for your help. It's really urgent!
Ciao Ali,
You have several ways to arrive at this result.
This is one using Lightworks by Dwight http://archicad-talk.graphisoft.com/viewtopic.php?t=6826.
Hope this helps
put all the images in a library (reload the library if ac is running)
type the name of the required image in parameter settings
bill
