‎2011-05-20 08:54 PM
‎2011-05-20 10:35 PM
‎2011-05-21 04:17 PM
Karl wrote:
Hey Jay,
Long time. They are not libraries, but library parts. Anyway, all you do is click that bright red "X" button when the embedded part is selected.😉
‎2011-05-21 06:42 PM
Jay wrote:Sorry I misunderstood. For next time, to play it safe, you can always save the embedded objects somewhere before deleting them. Select the object(s) and then click the disk-icon. Then you can re-embed if deleting them causes problems.
My Question was less of a how and more of a what if.
‎2011-05-21 06:56 PM
Jay wrote:It was weird that the embedded object(s) were so huge - MB. If they were really that big, deleting them should have reduced your file size. I've not seen the message about needing 64 bit to generate section/3D. How big is your file in MB? Have you run PolyCount? If so, what is the total polygon count for the model?
All seems fine with these library edits, although the resulting file size is not changed and the File still tells me that I need a 64-bit system to generate any section of 3D window. Also the Autosave takes about 45-seconds to 1-minute every time, which was a huge hassle. It is a complex model and does seem to work better in AC14. I may just have to upgrade from Windows XP to Windows 7 64-bit.
‎2011-05-25 02:17 AM
‎2011-05-25 03:16 AM
