Learn more
Quiestion !
how can i save an window or a door in archicad 8.1 ?
4 Replies 4
Aussie John
can you expand on what you are wishing to do?
Cheers John
[/size]
in archicad 7.0 it was very simple
just "save as" window or door (after you modelate them first)
in 8.1 i have no ideea how to do that
LiHigh
use subtype: Opening/Wall Opening/Window(wall)....or Door(wall)
Howard Phua
Win 10, Archicad 19 INT
Display your window or door assembly (built flat on the ground at the origin as always) in the 3D window.
From the File menu, GDL, Save 3D Model As ... you'll see the dialog shown below. Select either the middle button (window) or right button (door) before saving. This sets the (basic) subtype and nothing else is required if the opening is rectangular and you don't want parametric materials. Voila.
