ROOF ON GDL
I try to make ROOF Accessory with GDL
for that i start by make a GDL roof with the following AC coordinates:
ac_ref_coords, ac_coords, ac_pitch , etc....
you can see the result on the joined picture:
points coors are OK, but reference line is ........ so far x0@#éçe!!!
i take the ref line coords of the base roof on the 2d windows, and compared it with GDL roof ac_ref_coords parameters
they are the same
so i don't understand what happened, why the ref line go so far
so if anyone got the solution to this problem...
OK....
i was searching from two day, but find the solution one minute after post the topic !!!
if it can help somebody else, the x Axes off the roof accessorie is the ref line of the base roof.
so the ref line coords of the GDL Roof are 0,0, 1,0 ( a line on the x axes)
