ROOM_POLY_STATUS
JGoode
I'm trying to use room_poly_status to determine whether to display something in AC21.
However archicad doesn't seem to recognise it and says that there isn't a parameters called that.
How can I get this to work?
Thanks
ArchiCAD 23
Windows 10
Palawat
Just a simple text2 command.
I created a zone stamp sub-type, create a parameter "room_poly_status" and make it "integer" type.
In 2D script, it's just ;
text2 0, 0, room_poly_status
That's it.
Archicad 26, Windows 10, Corei7 3.4 GHz, 16 GB Ram.
https://www.indigofigs.com
https://www.facebook.com/indigofigs
11 REPLIES 11
ROOM_POLY_STATUS is only available to zone stamps.
JGoode
Yes, that's what I am making. Am I correct in thinking that this command is the 'Construction Method' of the zone?
ArchiCAD 23
Windows 10
Yes it just determines if it is a manually drawn zone, or auto fill to zone boundaries or auto fill to wall ref lines.
JGoode
Is it working in AC21? It just seems to return the value of 0 rather than 1 / 2 so I'm unable to use it.
Here is an example of its use:
	if (room_area <> room_net_area) or (room_area <> room_reduced_area) or (room_area <> room_calc_area) or (room_poly_status = 0) then
		stamp_error = 1
	else
		stamp_error = 0
	endif
ArchiCAD 23
Windows 10
Palawat
In "Zone Selection Settings" under "Name and Positioning", you will see options for "Zone Polygon".
If "Geometry method" is set to "Reference Line" and "Gross" is selected, ROOM_POLY_STATUS returns 2.
If "Geometry method" is set to "Reference Line" and "Net" is selected, ROOM_POLY_STATUS returns 1.
If "Geometry method" is set to "Manual" or "Inner Edge", ROOM_POLY_STATUS returns 0.
Tested with AC21
HTH
JGoode
So I've tried this using this code:
	 if ROOM_POLY_STATUS = 0 then text2 0, 2, "0"
	 if ROOM_POLY_STATUS = 1 then text2 0, 2, "1"
	 if ROOM_POLY_STATUS = 2 then text2 0, 2, "2"
and it still doesn't seem to work. Any Ideas?
ArchiCAD 23
Windows 10
Palawat
I'm afraid I ran out of idea.
Good luck.
JGoode
Do you have any example code which you have gotten to work?
ArchiCAD 23
Windows 10
Palawat
That's it.
