Remove quotation mark (inches) from text2
Hi guys.
I've tried to figure this out with the gdl reference guide but to no avail.
I'm trying to get rid of the quotation mark. It's either that or I have to add one to the 12. That's easy but I have no interest in doing that. I've included the text2 statement in the attachment. I started with decimal inches which worked fine but not everyone knows their decimals.I would appreciate a push in the right direction.
Thank you,
Doug
1 Reply 1
So, here's what I came up with. The extra lines in the Master Script are to deal with Archicad's accuracy.
I added a boolean to switch to decimal just in case. Seems to work pretty well.
Master Script:
TOTAL = B*39.370078740157
FRACTION = FRA(TOTAL)
WHOLE_INCHES = TOTAL-FRACTION
SIXTEENTHS = FRACTION/.0625
IF SIXTEENTHS > -1 AND SIXTEENTHS < .5 THEN FRACT = ""
IF SIXTEENTHS > .5 AND SIXTEENTHS < 1.5 THEN FRACT = "1/16"
IF SIXTEENTHS > 1.5 AND SIXTEENTHS < 2.5 THEN FRACT = "1/8"
IF SIXTEENTHS > 2.5 AND SIXTEENTHS < 3.5 THEN FRACT = "3/16"
IF SIXTEENTHS > 3.5 AND SIXTEENTHS < 4.5 THEN FRACT = "1/4"
IF SIXTEENTHS > 4.5 AND SIXTEENTHS < 5.5 THEN FRACT = "5/16"
IF SIXTEENTHS > 5.5 AND SIXTEENTHS < 6.5 THEN FRACT = "3/8"
IF SIXTEENTHS > 6.5 AND SIXTEENTHS < 7.5 THEN FRACT = "7/16"
IF SIXTEENTHS > 7.5 AND SIXTEENTHS < 8.5 THEN FRACT = "1/2"
IF SIXTEENTHS > 8.5 AND SIXTEENTHS < 9.5 THEN FRACT = "9/16"
IF SIXTEENTHS > 9.5 AND SIXTEENTHS < 10.5 THEN FRACT = "5/8"
IF SIXTEENTHS > 10.5 AND SIXTEENTHS < 11.5 THEN FRACT = "11/16"
IF SIXTEENTHS > 11.5 AND SIXTEENTHS < 12.5 THEN FRACT = "3/4"
IF SIXTEENTHS > 12.5 AND SIXTEENTHS < 13.5 THEN FRACT = "13/16"
IF SIXTEENTHS > 13.5 AND SIXTEENTHS < 14.5 THEN FRACT = "7/8"
IF SIXTEENTHS > 14.5 AND SIXTEENTHS < 15.5 THEN FRACT = "15/16"
IF SIXTEENTHS > 15.5 AND SIXTEENTHS < 16 THEN
WHOLE_INCHES = WHOLE_INCHES + 1
FRACT = ""
ENDIF
2D Script:
PEN PEN_COLOR
!!!!!!!!!!!!!!!!!!!!!!!!!CHANGING THE PITCH!!!!!!!!!!!!!!!!!!!!!!!!!!
unID=1000
hotspot2 12", 0, UNID, B,1+128 : unID=unID+1
hotspot2 12", -1, UNID, B,3 : unID=unID+1
hotspot2 12", B, UNID, B ,2 : unID=unID+1
LINE2 0, 0, 0, B
LINE2 0, B, 12", B
HOTSPOT2 0, 0
HOTSPOT2 0, B
DEFINE STYLE "PITCHTEXT1" "ARIEL", 1.75, 5, 0
DEFINE STYLE "PITCHTEXT2" "ARIEL", 1.75, 6, 0
set style "PITCHTEXT1"
TEXT2 6", B+3", "12"
set style "PITCHTEXT2"
IF DECIMAL THEN
TEXT2 -1", B/2, TOTAL
ELSE
IF FRACT = "" THEN
TEXT2 -1", B/2, STR ("%.0pt", WHOLE_INCHES)
ELSE TEXT2 -1", B/2, STR ("%.0pt", WHOLE_INCHES) + " " + FRACT
ENDIF
set fill 16
poly2_b 4, 2, 10, 91,
0,0,1,
0,B,1,
12",B,1,
0,0,1
