!Restored: Favorites Menu "Which One"
Are Favorites saved with the File.
Example : If I load my Favorites from a Favorites.prf file, edit the favorites but do not re-save the favorites. Once file is saved and re-opened, what favorite scheme is being used? Also is there a way to see what PRF file is currently being used with a file?
6 Replies 6
No. Favorites can be stored in any folder. I suggest that if you are a sole practitioner you create a special folder outside of the ArchiCAD folder in which to store them. For larger firms they can be stored on a server so that everyone in the firm can access them. See this thread on Favorites:
http://archicad-talk.graphisoft.com/viewtopic.php?p=30182#30182
Favorites are not like library parts; Favorites are stored Settings or Parameters for library parts or tools. There's a really good section on Favorites and using them in ArchiCAD Help (Help/ArchiCAD Help). Hit the Search tab; type favorites in the search field. At the top of the list will be a great explanation of what they are and how to use them.
Enjoy Favorites
woodster
woodster wrote:
...I suggest that if you are a sole practitioner you create a special folder outside of the ArchiCAD folder in which to store them.
woodster
I do this now Favorites Folder and a "CSE Template.prf" file.
woodster
Yes, I did not mean to say Object in the Object Sense,. Thanks for making this clear.
A screen shot shows my many Favorites.
Still, is there a way to see what PRF file is currently being used with a file?
Jay,
your list of Favorites is way too long to be of any use. Take a look at the link in my post above and break that list into parts as there suggested.
Or go to:
http://www.graphisoft.com/support/archicad/archiguide/TiponManagingFavorites.html
woodster
As far as knowing which Favorite list is "Current" Rashid had the work around here:
http://archicad-talk.graphisoft.com/viewtopic.php?t=5421&postdays=0&postorder=asc&&start=10
Jay,
the link you refered to is a wish... and a good one I might add. It would be good if the Favorites Title bar showed which Favorites file was active.
woodster
It may be a Wish, but a "work-around is to save a tool as a Favorite (no matter the settings) with the "*** Name***". For me I saved a Wall. I like to sort by type. The "***" force it to sort to the top by name as well.
