!Restored: Newbie Needs Help
Does anyone here know how to rotate a created GDL object in the vertical plane? Thank you!
David Maudlin
Blackspots7:
There are 2 approaches:
1. Simple: Change the parallel type view in the 3D window so which side you want to be up is on top, and recreate the object. The rotation will not be parametric.
2. Complicated: Add a parameter to the object and a rotate command to the 3D script. This will make the rotation angle parametric.
This has been covered many times before on the forum, so do a search for more detailed instructions for either approach.
HTH
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
