rob2218
Roof Slope Object - anyone?
anyone has an object that accomplishes this?
i>u
Edgewater, FL!
SOFTWARE VERSION:
Archicad 22, Archicad 23
Windows7 -OS, MAC Maverick OS
6 Replies 6
Stress Co_
Won't do exactly what you want to do, but there's a "Roof Slope"
object on the BIM Components Portal.
Truth be told. It's kinda useless as you can't do fractional slopes
or easily change fonts.
Marc Corney, Architect
Red Canoe Architecture, P. A.
rob2218
thanks...yeah, I need it to be able to do what I need it to do.
be able to as you change the lines, the numbers on the roof slope change.
basically, have the line "information parameter" with regards to the length be directly tied to the 2d graphics of the triangle slope pline.
i>u
Edgewater, FL!
SOFTWARE VERSION:
rob2218
where is the BIMPortal site?
I'd like to take a look at that object but can't seem to find the bimportal easily?
i>u
Edgewater, FL!
SOFTWARE VERSION:
Stress Co_
bimcomponents.com
or you can get there from the object search box.
rob2218
Marc,
I tested the object.
sorta does what I need it to do but you are right...
it's got these preset slopes that if you need to deviate from it...say you need a 6.5:12...it won't do that.
it should be programmed to do the opposite, you stretch the line to whatever nearest fraction you have and the number changes according, rounding up to say....0.25 of a whole number.
i>u
Edgewater, FL!
SOFTWARE VERSION:
rob2218
and the sad part is that when you try to "open" the objects to see it's programming parameters, the owner "passworded" the object. hubboy.
i>u
Edgewater, FL!
SOFTWARE VERSION:
