SE9 GARAGE DOOR OPENING LINE
I can't seem to turn off the 2D opening line for the garage doors in the SE9 door settings (Floor plan symbol-ghost opening line) I can turn it off but the opening line is still on the floor plan. Am I missing something?
Thanks,
Jim
Anyone?
Is anyone having the same problem?
Thanks,
Jim
The Ghost Opening Line isn't supposed to turn off the garage door opening linework (which corresponds to the swing of a hinged door). Display Options do that.
It doesn't actually do anything for an overhead door, so I think it was an oversight that the parameter was left in the object.
Take a look at a D1 Entrance door for example, and turn the Ghost Opening Line to "on" (check) ... you now have an angle parameter to show the dashed 'extended opening' area on plan. Note that there is no way to turn the base swing linework off, other than using Display Options. Ditto the garage door.
Karl
