Showing results forΒ
Search instead forΒ
Did you mean:Β
Search instead forΒ
Did you mean:Β
SHAPE JM9 TAG
Hi Archicad users,
I have been using the shape JM9 tag for a long time now, but as soon as I installed AC13 and performing an AC to DWG translation the tag text disappear in AUTOCAD. It doesn't do it in AC12. The translation works perfectly.
Is anyone experiencing the same problem??? How can I fix it?
Thank you for all your posts..
DDJUSA
1 Reply 1
It sounds like something to do with the translator settings. Have you tried opening up AC12 and 13 at the same time and manually comparing the settings? I understand there are some new dwg translator features introduced in AC13 so perhaps check these first.
