Save folder content's as favorite
hi all,
is there a way to easy save a folder content of gsm objects as favorites?
thanks,
Florian
Do you mean you want to create a group (folder) of objects from the library as favourites?
If yes then no you can't.
You must save each object as a favourite separately.
Then you can place them in folders within the favourites.
If you mean you want to save (export) a folder of favourites from the favourites palette then yes you can (in version 20).
Just select the folder, go to the favourites setting button, and choose to export selected favourites only.
ok - Then i have to do it one by one.
Thanks for fast answer!
Florian
