Searching for Door Object
This is my first post so sorry if I have not given enough information.
I am a previous version 8 and upgraded to 10. I am not very knowledgeable in Archicad. I am looking for a door with a dbl. sidelight on one side, and for the life of me I went thru every door style and cannot find the option to create it.
Can someone please help me out! Please ask any questions to help me out.
Thanks,
Taunya
7 Replies 7
TomWaltz
by double sidelight, do you mean two sidelights on the same side of the door?
If so, I don't believe I've ever seen such a thing.
Tom Waltz
Yes that is what I am talking about.
Erika Epstein
You can make one with the storefront and/or curtain wall parts.
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
If you mean a double sidelite (i.e. one above the other), then the standard D1 Entrance Side 1 door should work. You just select a different sidelite type. (In AC11, it's style 2, probably the same in AC10).
Richard
AC26 (since AC6.0), Win10
Very sim. to what I am looking for except I would like to have a vertical
mull yet in the sidelite, to make it a 4 pane sidelite. I hope someone can help me out.
I went thru all the options in the D1 w/ sidelite but could not add a vertical mull in it. I will have to try the store front door again I guess I never tried using the curtain wall parts.
So just add a short wall or tall slab segment at that location. Done.
Richard
I understand what you are talking about , So will this still generate in the door elevations the correct way?
Also what about using BIM, now it probably won't calc. this the correct way.
