Sewer - Library part
Hmooslechner
If there is someone interested in my Sewer - Library Part, i woult translate the setting-Parameters to English.
Workflow:
You have a 3D-Surface of Your enviroment.
You use the normal way of putting new points at the polygon-way of the sewer in Your surface.
Then You draw the points of the Libraray-Part to the exact wantet points.
The Librarypart draws You a extra rollout-section of the Sewer, which You can draw around Your drawing. In this extra rollout-You can draw nearly all points of hights -whatever You want - and You get a real 3D-Sewer
have a look at the german Youtube-Vid to get the idea:
www.youtube.com/watch?v=ry7Rn9r0lws&feature=youtu.be
As written before- i would translat the paramerters for You, if somwone would find this useful..
Or maybe You translate it for Yourself..
In the Meantime, You could try my "beta" Archicad 16 Edu Aut:
https://www.dropbox.com/s/trtoa9q5jhafb0m/Kanal%20e.pln
enjoy!
19 REPLIES 19
Hmooslechner
youtu.be/Kc_x3acX6BU
this english tutorial is in upload now for a while.
the old link if the edu-File contains now an international "nearly english" library Part.
Please be so kind and tell me better vokabularies for the parameters - i had to translate it with Web-translaters...
and here is the naked library part:
https://www.dropbox.com/s/3curdcr56kla4q7/Kanal2_Int1.gsm
I am developing this sewer SHAFT. This is mine third project (after 2D Tube and Sewage pipe_INT......https://bimcomponents.com/GSM/Details/13466).
Section:
And Plan View:
I looked at your new version, better good. Yet my superficial observations:
Change the type of the parameter to an integer
I do not use the special menu - stop error messages library feature (Interpurt with Library part ERROR messages)
Array index error. I am sorry that I have slightly edited the your script. Though the item to me personally for the practical work is not generally useful, but I think it could be very promising for further development.[/img]
Hmooslechner
Thanks to SL_GDL!
Someone who reads code! Wonderful!
I put in Your suggestions.
By the way - feel free to use the code-structure in Your projects! - And let me know Your results.
I noticed, You named Your attached suggestion - picture in german "subjektive_beobachtungen_206.png"
It seems for me - Your native language could be german. if this is correct - please let me know Your suggestions also at www.archiforum.net - the german Archicad forum, because it would be much easier for me to understand your inputs in german.
So You can understand my question:
Why alter the Parameters SLG and SLG1 from noun to integer?
Gops
Hi Hmooslechner,
I have just try your sewer object and I must say that it is very smart.
Thanks for making it free.
Gops
AC 16-17, Win 7 4 Gig RAM
Hmooslechner
thanks for the flowers!
This looks great, English version would be greatly appreciated.
Hmooslechner
https://www.dropbox.com/s/bjqpf7oqkfzspvp/Kanal_M.pln?dl=0
Edu-Aut-Version. It contains also an englich version!
