Shape Tag Update
It looks like a number of people have downloaded my Shape Tag object, so I thought I should post a notice of this minor update.
I added a switch parameter for Mask, which simply fills the shape with a solid white fill. There are parameters for the solid fill and the white pen, so you can 'localize' it as needed.
I tried to update the file in the d/repository, but that returned fail. So if you have ever wanted a masking fill in your shape tag, you can download the new one directly from me. The file name is unchanged and the mask defaults to off.
HTH,
James Murray
Archicad 29 • Rill Architects • macOS • OnLand.info
1 Reply 1
Rod Jurich
James wrote:
/..... There are parameters for the solid fill and the white pen, so you can 'localize' it as needed./....
Many thanks, James.
Season's greetings to you, and everyboby.
Rod Jurich
