Sink in Cabinet
This is Sink Corner 11 over standard cabinets. I have a separate slab that I cut a hole in for the sink. Now how do I get a cutout in the cabinets?
undefined
2 REPLIES 2
Solid Element Operation - subtract with upwards extrusion - if the sink has been modelled as a solid object (not just surfaces).
If that doesn't work add in a slab the shape of the sink bowls and SEO that with the cabinets.
Hide the slab in a layer that you don't see in your normal views.
The second way worked great. Thanks!
