SA-shoji
Custome Cabinet design
I have already made a custom cabinets. Now i want to increase its height, add new drawer, change material and delete some parts.
So how can i edit it so easily and quickly?
1 Solution
Lingwisyer
Guru
Well, if your carcase is a seperate morph to your drawers, you could isolate it in 3D then use Sub-element Selection to select all of the upper elements, that you can then move vertically the required amount.
Then do the same with your drawers, prior to duplicating.
Ling.
Go to post
3 Replies 3
Lingwisyer
Guru
How did you create it?
SA-shoji
By morph tool. Now i am editing that on 3d window but it takes lots of time. So, i am looking for easiest way
Lingwisyer
Guru
Ling.
