3 weeks ago
I have already made a custom cabinets. Now i want to increase its height, add new drawer, change material and delete some parts.
So how can i edit it so easily and quickly?
Solved! Go to Solution.
3 weeks ago
Well, if your carcase is a seperate morph to your drawers, you could isolate it in 3D then use Sub-element Selection to select all of the upper elements, that you can then move vertically the required amount.
Then do the same with your drawers, prior to duplicating.
Ling.
3 weeks ago
How did you create it?
3 weeks ago - last edited 3 weeks ago
By morph tool. Now i am editing that on 3d window but it takes lots of time. So, i am looking for easiest way
3 weeks ago
Ling.
