Geof Gainer
Sink with Tap: tap models too high over counter
Multi Style Sink, when undermounted and selected with tap, shows up with the tap floating a couple inches above the counter. Is this adjustable for different counter thicknesses? It's as though the tap object has its origin set too low.
AC fan since v 7. Currently on AC 28.1.1 (4100) USA FULL, Apple Silicon,. 2022 Mac Studio, 32G ram. MacOS Sequoia 15.5
2 Replies 2
Geof
That is a problem with the Object itself.
Graphisoft should fix it.
I know that can take several months , so Here I have fixed it by adding the parameter missing [ count_th ]
With that parameter you can change manually the height of the "imaginary" countertop
Download the file attached and include it in your library.
Note: this works for ArchiCAD USA only.
Best Regards
Nando
Nando Mogollon
Director @ BuilDigital
[email protected]
Using, Archicad Latest AU and INT. Revit Latest (have to keep comparing notes)
More and more... IFC.js, IFCOpenShell
All things Solibri and BIMCollab
Geof Gainer
You rock.
