Sliding doors
Where can I find a sliding door with more that 3 panels (the one from the library has only 3). Can I change the number of panels. I need a 4-6 panels sliding door - all panels slide in one direction (NANA wall).
Please
4 REPLIES 4
If you find one, let me know as well. I have been looking for a decent one for a while and I'm not clever enough to code one (yet!). It has been requested before - do a search for NANAWALL.
The way I approch it at the moment is to use the sliding door frame with the original panels turned off. I then create my custom panels using slabs and save them as dumb library parts. Not ideal, but it gets the job done. You will have to add the required 2d lines manually too.
Hi carmenstan,
I've used one before from the "Menuiseries FRA_SUI v2.lcf" libraries from Abvent.
Free choice of 2-7 or more panels, all in one direction like you asked
I forgot :
just google "Menuiseries FRA_SUI v2.lcf" and you wil find the free download for AC11 from the Abvent website
Thank you
