Start Archicad with a different library?
I am using the USA library for my projects. I am watching some videos which need the Int library to load properly. I have both libraries loaded to accommodate this but it creates thousands of duplicate parts. Is there a way to start Archicad with the appropriate library only (not have both loaded at the same time)?
KrisM
Just open the Library Manager and add/remove the libraries that you require.
Each file will remember the settings you make when you save the file, so next time you open it, the correct libraries will load if they are available.
That's simple. Thanks for that.
