2013-03-11 09:20 AM
2013-03-11 01:55 PM
2013-03-11 10:29 PM
2013-03-12 08:15 AM
2013-03-12 12:43 PM
2013-03-12 02:31 PM
rocorona wrote:The built-in marker can be opened by using the Open Object by Subtype... command and going to Drawing Symbol > Marker > Story Marker > Built-in Story Marker.
One problem is you can't look to any example on how it sould be written, as I think the "basic" marker is embedded it ArchiCAD itself, and you can't open it without knowing the exact name (I think it can't be found browsing an lcf-extracted library).
hamedkassaei wrote:Is the object scripted (using the 2D Script window) or drawn (using the 2D Symbol window)? I think it must be scripted.
I did it !!! every thing was okey ... I made a new 2d object ... changed its type to Story marker Type ...It appears it Story marker option but ... when I choose it , I will display nothing in Section ..although I saw what i made in preview !!!
what is wrong with it ?!
2013-03-12 11:16 PM
David wrote:Thanks! I did forget about this command, that was missing in my Work Environment.
2013-03-13 09:55 AM
