Learn more
Stretchy 2D lines
I have drawn some lines using LINE2 in my 2D script and I need them to stretch with the size of A&B. I'm guessing I need to use MUL but I have yet to figure out how to use that command. Can anyone enlighten me?
2 Replies 2
gerd
hi,
you can use two different ways:
1) with 'mul2 x,y' you can stretch the things behind the command. you can use line2, circle2 or also the fragment2 command. of course the circle will get an ellips, if x and y are not identical. if typical values for a is 2.0 and for b 1.2 then you can script: mul2 a/2.0,b/1.2 ...
2) you can define the elements in dependency to a and b:
line2 0,0,a,0
line2 0,0,0,b
This way is more difficult but sometimes you need more control over the elements.
best regards. gerd
Using the MUL2 I got it to work. I had to use:
MUL2 A*3.25,B*3.25
Which seems odd to me, but at least it works so I'm not complaining.
