Structure Display
Hi everyone,
I have a problem with displaying window with insulation clousure on a facade. I want to show existing(without insulation) and project (with insulation) facade. When i turn on structure display to without finishes, it doesn't display it corectly on plan and on facade it doesn't change at all.
Katalin Borszeki
Hi! Please specify the update number and setup of computer you are using!! It is impossible for us to identify your problem without the knowledge of that information. You could setup your signature that way!! Thanks, k
Katalin Borszeki
Implementation Specialist
GRAPHISOFT
http://helpcenter.graphisoft.com - the ArchiCAD knowledge base
