ReignBough
Swap parameters
I am creating an object that has a portrait/landscape parameter. When one of these is selected, the corresponding width and height should also change accordingly. Any idea how to do this?
I am using the basic swap:
IF GLOB_MODPAR_NAME = 'param_or' THEN
  tmp = param_wd
  PARAMETERS param_wd = param_ht
  PARAMETERS param_ht = tmp
ENDIF
~ReignBough~
ARCHICAD 27 INT (since AC18)
Windows 11 Pro, AMD Ryzen 7, 3.20GHz, 32.0GB RAM, 64-bit OS
Hello,
I do not know if this serves....depends on
how you want it work;
!--master or value script
if param_or= 'Landscape' then
   xx= a
   yy= b
endif
if param_or= 'Portrait' then
   xx= b
   yy= a
endif
parameters param_wd=xx, param_ht=yy
