Kevin wrote:
Secondly, will I have to reassign textures to surfaces from the textures library before deleting files from the embedded library?
No so long as they are in at least one loaded library, Archicad will find them automatically (but not if you have renamed them).
If they exist in more than one loaded library, that is when you will get warnings about 'Duplicates'.
You can then see where they are and delete one of the duplicates (in this case from your Embedded Library'.
