3 weeks ago
Hi All,
When creating an office template - How do you decide when to put something in the embedded library vs a linked library?
Are there ever any instances where you'd put something, like textures, in the template's embedded library or is it best to just put everything in a linked office standard library?
Thanks!
Solved! Go to Solution.
3 weeks ago - last edited 3 weeks ago
The template should have nothing or minimal embeded library clutter.
It is best practice to have all of that baseline information in your office library that is Loaded / linked into the template file.
Embedded libraries are only good for that particular job (file) and don't get updated unless you manually do this.
Keep everything in an office library that you can keep up to date.
So long as your file links to the updated library, you will have no issues.
3 weeks ago
Also, consider that an office library is a library used by most or all projects. So, its contents should not be embedded into any individual project file. It should be located in a storage device (or in BIMcloud) from where it can be easily linked into all project files.
