Scott Bulmer
Translation of International to US Electric Symbols
To those familiar with both the International and US electrical symbols in the INT & US libraries;
I need to translate or identify the equivalent symbols between the two libraries. For instance in the US, a receptacle outlet is represented by a circle with two lines through it. I don't readily see the International counterpart. Further in the US, a single pole switch is represented by an 'S' with a line through it. What is the International representation? I need the information for the basic, most common symbols: switches, outlets, fans, lighting fixtures, etc.
Thank you for any comments,
Scott
AC27 v. 4060 w/ MEP, Cadimage, Twinmotion 2023.2.2 using AC from AC6.0, 2021 MacPro M1 chip, Adobe CC. Used AC on both platforms.
0 Replies 0
