Transparancy in Elevations
This is a new feature to Archicad 9 and it's driving me nuts! I use Anderson window and door modules in my housing models, and for some reason, the glass becomes transparent when i generate elevations. This results in a good deal of lost time deleting lines that show through the windows. Is there a way to turn off this feature?
Scott Graham, AIA LEED BD+C
Principal | BIM Manager
Muhlenberg Greene Architects, Ltd.
Wyomissing, PA 19610
V6.5-26.0
2 Replies 2
__archiben
scott
3D transparency status is saved BY VIEW. if you flick between windows using saved views the transparency settings will also change to that saved with the view . . .
this is A Good Thing. but completely un-obvious.
~/archiben
b e n _ f r o s t
got it. thanx.
V6.5-26.0
