Trees & plants
Can anyone give me advice on tree libraries that give reasonable output when rendered in ArchiCad. Current using Garden Works Library.
Have just looked at OnyxTree.com they look great. Do you need to use these with Art.lantis or can you just use with ArchiCad?
Thanks in advance
Andrew
10 Replies 10
Dwight
Since they are 3D trees with real materials on the surfaces, they DO work with Artlantis or any other renderer - When using Artlantis, you could allow yourself less polygon reduction because it renders more quickly - I have succeeded with Onyx by eliminating the smaller twigs and branches, making larger flat leaves and fewer of them...
there's a tidy dialog for this when saving the tree in onyx.
Dwight Atkinson
stefan
Why don't you use Billboards?
Real 3D trees (like Onyx, XFrog and others) can take so much geometry that it slows everything down.
I wouldn't use them in ArchiCAD. I might use them in external rendering software.
Archicad-user since 1998
my Archicad Book
Dwight
It is a question of satisfaction.
I've never been satisfied with billboards even though they are necessary when the count gets too high.
Dwight Atkinson
stefan
Support for RPC objects would be a good solution...
And the LightWorks engine supports it (but I guess not in the Lightworks licensed engine in ArchiCAD 9.0).
http://www.lightworks-user.com/downloads.php?type=supplier&filter=Archvision
my Archicad Book
Dwight
that is correct, but those are still flat things, too......
Nothing beats real 3D....
Dwight Atkinson
stefan
And what about EASYNat?
Hybrid trees that can optionally be full 3D, full 2D or partly 3D (trunk) and 2D (leaves)?
It's available as a plugin for 3ds max and possibly others as well.
my Archicad Book
Dwight
What about it?
Seems good.
Can these features be used in ArchiCAD?
Dwight Atkinson
stefan
Dwight wrote:
What about it?
Seems good.
http://www.bionatics.com/home/indexc.php3
EASYnat is only available for 3ds max, VIZ and VIZ Render. natFX is also available for Maya.
my Archicad Book
Dwight
Swell.
Would there be a way to port it into ArchiCAD?
Dwight Atkinson
