ares997
Trees (and other objects) Fill-Type not Gradient Enabled
I'm trying to make some fancy trees with a gradient fill in them but can't really see why they can't be gradient nor where to adjust the code to make them gradient....so this is a stock ac14 trees' 2d script (out of the box):
unID = 1
pen gs_cont_pen
if type=`Simple` then
hotspot2 0, 0
hotspot2 a/2, 0
hotspot2 -a/2, 0
hotspot2 0, b/2
hotspot2 0, -b/2
circle2 0,0, a/2
circle2 0,0, diaTrunk/2
fill gs_fill_type
poly2_b 2, 2, gs_fill_pen, gs_back_pen,
0,0,900,
a/2,360,4000
else
for iType = 1 to 40
if stSymbolType[iType] = type then
macroName = stSymbolMacroName[iType]
call macroName parameters a=a, b=b,type=stSymbolInMacroType[iType], cont_pen=gs_cont_pen,
fill_type=gs_fill_type, f_pen=gs_fill_pen, b_pen=gs_back_pen
endif
next iType
endif
! TEXT
nTrans = 0
if txt_show then
hotspot2 txt_pos_x, 0, UnID, txt_pos_y, 1+128 : unID=unID+1
hotspot2 txt_pos_x, -1, UnID, txt_pos_y, 3 : unID=unID+1
hotspot2 txt_pos_x, txt_pos_y, UnID, txt_pos_y, 2 : unID=unID+1
hotspot2 0, txt_pos_y, UnID, txt_pos_x, 1+128 : unID=unID+1
hotspot2 -1, txt_pos_y, UnID, txt_pos_x, 3 : unID=unID+1
hotspot2 txt_pos_x, txt_pos_y, UnID, txt_pos_x, 2 : unID=unID+1
pen txt_pen
define style fe1 fontType, fontSizeFixed_mm, 5, isBold + isItalic * 2 + isUnderlined * 4
style fe1
add2 txt_pos_x, txt_pos_y
nTrans = nTrans + 1
! --- Oriented View ------------------------------ [
angleViewRot = 0
rrr = REQUEST ("View_Rotangle", "", angleViewRot)
totalRotate = (SYMB_ROTANGLE + angleViewRot) MOD 360
! Text Rotation - Readable / Always Horizontal / Align with Symbol
if typeTextRotation_m = 2 then ! Readable
if (totalRotate > (gs_readable_angle + eps) & totalRotate < (gs_readable_angle + 180 + eps)) then
rot2 180
nTrans = nTrans + 1
endif
else
if typeTextRotation_m = 1 then ! Horizontal
rot2 totalRotate * (SYMB_MIRRORED - not(SYMB_MIRRORED)) ! 1/-1
nTrans = nTrans + 1
endif
endif
text2 0,0,txt
del nTrans
endif
end
call "tree_2D-01" parameters all
call "tree_2D-02" parameters all
call "tree_2D-03" parameters all
call "tree_2D-04" parameters all
call "tree_2D-05" parameters all
call "tree_2D-06" parameters all
call "tree_2D-07" parameters all
call "tree_2D-08" parameters all
call "tree_2D-09" parameters all
call "tree_2D-10" parameters all
call "tree_2D-11" parameters all
But when I go to the variable for the Fill type in the parameters the variable doesn't have an option for gradient.
All suggestions
Archicad 25 (5005), Windows 11, AMD RYZEN 7 3900 (64 GB RAM)
1 Reply 1
Pertti Paasky
ares997,
Try to replace
0,0,900,
a/2,360,4000
with this:
set fill gs_fill_type !or [set fill "gradient fill"] (check the name, please)
poly2_b{5} 2, 3, 0, 12,
0, .3,
1, 0, 0, 1,
0.3,
0,0,900,
a/2,360,4000
check details GDL Reference quide page 150 (AC !3)
You can also draw Your tree 2d in plan wiew and then drag it into an object´s 2d program window. Then You can copy the code into Your object.
poly2_b{5} has lots of controll flags, be patient...by adjusting them You get what You want.
If You can´t get the gradient fill from the dialog box, just write it like You get it from dragging it in the 2d window
- AC-24 FIN - WIN 10 - HP Zbook -
“A winner is just a loser who tried one more time.”
George M. Moore, Jr.
