Trouble moving door tags in AC10
Moving doors tags has always been a little problematic, but I am finding that in 10, standard tags only sometimes move, and then only in one axis. Has anyone posted a "fixed" NCS 10 tag? (Or know of any similar tag that actually works?) Or maybe knows the trick to get the standard ones to work reliably?
On a similar topic, it appears that the NCS window tags can be moved ONCE, and then you're stuck.
Richard
AC26 (since AC6.0), Win10
Link
Don't ask me why, but it seems that you can move the marker horizontally with one hotspot and vertically with another. Try streatching all the diamond editable GDL hotspots.
Can't replicate that here -works fine. Like the door tag should!
Link.
Yeah, somebody must have written that part before they figured out how to change two parameters with one hotspot - or else they they thought it was a feature
It's a bit of a pain having to move it twice but it should work. Of course I've written my own since the NCS ones don't do what any of my clients want.
