giza
Two free GDL objects: parking layouts and solar parks in a site polygon
Hi all,
We've built two parametric objects for early site studies and I'm sharing them free with the community.
archiParkingLayout: draw your site as a polygon (drag the corners) and it fills it with surface parking:
  • 90°, 75°, 60°, 45°, 30° or parallel stalls, with aisle widths and one-way/two-way traffic following the angle
  • best fit: rows turn and shift to fit the most stalls, and refit whenever you move a corner
  • a ring road or end lanes so every aisle connects, entrances, and rounded islands at the row ends for turning
  • optional trees (a planted bay every N stalls, trees on the islands), cars in plan and 3D
  • stall count, m² per stall and stalls per hectare in the info block
archiSolarPark: place it on a plot and it lays out a ground-mounted solar park:
  • fixed-tilt rows, single-axis trackers or east-west tables, turned to the sun using your project's location
  • rows spaced so they don't shade each other, plus fence, roads, inverter stations, substation and battery
  • module count, MWp and a rough yearly energy estimate in the info block
Both are free downloads, as one library file or as single objects:
https://www.architools.net/libraries
Help pages with worked examples:
They're meant for feasibility and massing, not final design: check stall sizes and aisle widths against your local standards. Feedback and bug reports are very welcome. Tell me what's missing for your projects.
parkinglayout (1).pngSolarpark (1).pngparkinglayout (2).pngSolarpark (2).png
Gezim Radoniqi | Architect |
0 Replies 0
