Uploading Old Files onto BIM Server Library
Hi!
Not sure if anyone else has noticed but there's a limitation in uploading image files for surfaces in that files created before January 1st 2001 will generate an error message:
"File Creation Date Not Available"
And I thought the Y2K bug was dead..
1 REPLY 1
Katalin Borszeki
Hi All,
Unfortunately we did not get a response from khairulfikri so we could not move forward with the investigation
Katalin Borszeki
Implementation Specialist
GRAPHISOFT
