2014-02-10 05:43 AM
ch1 = OPEN ("DATA", "RevisionControl.txt", "MODE = WA")
OUTPUT ch1, GLOB_INTGUID, 1, LayoutID, LayoutNumber, LayoutName, RevID, RevSub, RevNote, RevDate, RevPerson
CLOSE ch1
I'm using the GLOB_INTGUID as the data key because this is then a unique number for each marker that can be updated in the database if the marker object is modified. The LayoutID, LayoutNumber and LayoutName variables are requested from the layout page by the object and the various Rev__ variables are user entered data.ch1 = OPEN ("DATA", "RevisionControl.txt", "MODE = RO")
RevData = INPUT (ch1, "???", 1, LayoutID, LayoutNumber, LayoutName, RevID, RevSub, RevNote, RevDate, RevPerson)
CLOSE ch1
Once I find a way to get multiple rows of data in (to an array?) I then need to be able to filter down to just the marker data for objects on this page of the layout book.2014-02-10 08:21 PM
! Example to read all string values from a file
! and use it in a value list
DIM sarray[]
! file in the library, containing parameter data
filename = "ProjectNotes.txt"
ch1 = OPEN ("text", filename, "MODE=RO, LIBRARY")
i = 1
j = 1
sarray[1] = ""
! collect all strings
DO
n = INPUT (ch1, i, 1, var)
IF n > 0 AND VARTYPE (var) = 2 THEN
sarray = var
j = j + 1
ENDIF
i = i + 1
WHILE n > 0
CLOSE ch1
! parameter popup with strings
2014-02-11 01:49 AM
2014-02-11 03:09 AM
2014-02-11 04:01 AM
2014-02-11 05:34 AM
2014-02-11 05:42 AM
2014-02-11 06:10 AM
MASTER SCRIPT
n = REQUEST ("HomeDB_info", "", LayoutID, LayoutNumber, LayoutName, LayoutContext)
index = (LayoutID * 100) + RevID + (RevSub / 100)
OUTPUT ch1, index, 1, LayoutID, LayoutNumber, LayoutName, RevID, RevSub, RevNote, RevDate, RevPerson
CLOSE ch1
The Listing Object then reads this data;
MASTER SCRIPT
n = REQUEST ("HomeDB_info", "", ThisLayoutID, ThisLayoutNumber, ThisLayoutName, ThisLayoutContext)
! Create an array to put the data in
DIM RevArray[][5]
i = 1
j = 1
RevArray[1][1] = ""
! Open the text file containing the Revision data
ch1 = OPEN ("TEXT", "RevisionControl.txt", "MODE = RO")
! Collect all strings
DO
RevData = INPUT (ch1, i, 1, index, LayoutID, LayoutNumber, LayoutName, RevID, RevSub, RevNote, RevDate, RevPerson)
IF LayoutID = ThisLayoutID AND RevData > 0 THEN
RevArray[1] = RevID
RevArray[2] = RevSub
RevArray[3] = RevNote
RevArray[4] = RevDate
RevArray[5] = RevPerson
j = j + 1
ENDIF
i = i + 1
WHILE RevData > 0
! Close the data source
CLOSE ch1
Problems that still exist;2014-02-11 02:50 PM
2014-02-11 06:13 PM
