ā2009-10-20
03:47 AM
ā2023-05-24
12:39 PM
Rubia Torres
ā2009-10-22 12:40 AM
ā2009-10-26 08:58 AM
Erika wrote:I'm not quite sure what you mean. Would you ArchiCAD to store the loaded-library info in MOD files?
Zsolt,
I have been having to spend a lot of time reloading libraries in module files when I choose edit this module in a separate archicad file. Can this be changed?
ā2009-10-26 09:01 AM
jim wrote:I still don't see the situation totally clear. Please report this problem to GS technical support with some example plan files. Based on that, they will tell you whether it can be fixed in ArchiCAD or in your files.
The problem is what it is. Despite referencing the same libraries. The migration 11 libraries will not come through as they should in a host file. So I do not know what to do. I think this is a bug.
ā2009-10-26 09:14 AM
ztaskai wrote:Yes, that is it. When you open a mod file by right-clicking and choose 'edit this module in separate archicad file', all the loaded libraries should [ideally] be loaded.
Regards,
Zsolt
