Find the perfect object, manage libraries, create custom objects
Variables for dimension whe creating gsm object
I have objetc and what to change type of dimension i what to have arrow insted of line in agle 45'.
I open my gsm object in open object and can access parameters, an need to add new variable to contrl what marker typeof dimension i want.
1 REPLY 1
To the best of my knowledge you can not add dimensions in a GDL script.
The 45° angle line must be scripted as a line.
For the arrow you will need to susbstitute it with a filled polygon.
If you need a choice between the two then you will need a parameter and an IF > THEN statement.
Otherwise just dimension your object as you would anything elese in plan and you will have complete control over the dimension settings.
If your object has hotspots with uniqu ID's then any dimension you add will stretch with your object if it changes.
Or am I not understanding what you mean?
