Wallhole slab does not cut wall hole.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
‎2008-12-03
11:06 PM
‎2023-05-24
11:58 AM
Rubia Torres
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2008-12-03 11:55 PM
Roland wrote:You don't say what version and platform you are on, but it works fine in 12, which I assume you're on. Are you sure that only ONE slab in your assembly has the ID=wallhole? Post a screenshot of what you are saving if that isn't the problems...
I can not get the wallhole function to cut a non-rectangular hole. I've used this tool in previous versions and it works fine. When I create a slab with the wallhole ID and create a window, the wallhole slab shows up when the window is placed. Any suggestions would be appreciated.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2008-12-04 05:37 PM
I'm on V12 on a Mac running 10.5.5. I've created the window geometry from slabs and only the glass, which extends to the limits of the opening is ID'd as "wallhole." All slabs are at or above the project zero elevation. I've done this a hundred times in previous versions, but it won't work in V12. Ironically, one of my coworkers is attempting to do the same thing and he can't get it to work either. He's on an Intel Mac and I'm on a Power PC Mac. Both of us have been using ArchiCAD since V5 so we are not unfamiliar with the process.
When the window is placed in plan then viewed in 3D, the wall hole is rectangular (the window isn't).
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2008-12-04 07:10 PM
So, it is not a general software problem.......
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2008-12-04 07:24 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2008-12-04 07:32 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2008-12-04 07:38 PM
BTW: where are you id-ing the wallhole element?
In the script or in the object dialog before saving?
I save from the 3D window.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2008-12-04 07:43 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2008-12-04 07:59 PM
If you save as binary, it can't read the wallhole data, i bet.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2008-12-04 08:07 PM
