Walls & Doors Disappear!!!!!
I'm having this problem with AC 12. I started out drawing the layout without setting the walls to the correct height. When i try editing the height, the wall just disappear. Can anyone help me with this problem. By the way, nothing was wrong when I starting drawing the first part.
Thank You.
Dwight
That will be your floor plan cut plane height being lower than your walls.
Move the walls to a higher story [using the 3D view] or adjust the plane upward. OR set relative view showing upward. Play with it.
Document>Floor Plan Cut Plane.
Dwight Atkinson
David Maudlin
rx_rotory:
If you just want the walls to display only on their home story, just change the walls' parameter under Floor Plan and Section > Floor Plan Display to "Symbolic Cut", this will ignore the Floor Plan Cut Plane.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
