Where to get Human Figures - People ?
I'm looking for a blank human figure ( no physical features, clothing etc. ) that I can show to represent the size of a model I'm making ( tent ). I also need the model to interact with the person i.e the human needs a back pack over his shoulders i.e a figure I can manipulate such as changing arm positions ?
The ones in the library aren't what I was looking for and I couldn't fine a suitable one in the GDL library.
6 REPLIES 6
Did you see the mannequin figure in the Object Depository? Look under 01 General > People > "Omuncolo by CU mirco".
It looks like you can adjust the position of the limbs and joints. I don't know how you will add a backpack to it though!
Thank you, I have just downloaded it. Do I add the file to the ArchiCAD library ?
Create a folder somewhere on your machine to place any downloaded library parts in. In ArchiCAD, open the library manager, then navigate to and add the folder you have just created. Any objects in it will now be available for use.
If you add any more objects to the folder while ArchiCAD is still open, just go back into the library manager and press reload.
Simple!
Hope that helps.
That has worked just fine thank you.
The model is very flexible ! I will look for a different one as this is a little too skeleton like and wouldn't look too good in my presentation.
May I know what kind of tent are you trying to build? You know what, I am also making Pop up canopies that will surely easy to assemble during outdoor activities. I just want to know about that tent you are trying to make.
vistasp
Mary, try the tentmaker object here:
http://pagesperso-orange.fr/archilib.od/
= v i s t a s p =
bT Square Peg
https://www.btsquarepeg.com
| AC 9-27 INT | Win11 | Ryzen 5700 | 32 GB | RTX 3050 |
