Display malfunction of Graphisoft ID dashboard
Learn more
Window W/ Transom
Hello everyone
what is the easiest and most presentable way when viewing 3D, to have "W Single Hung2 SE9" WITH TRANSOM?
So my question is how can i add transom to above mentioned window
Thanks
15 Replies 15
That particular window doesn't have a transom option, but you can turn on ganging for the top of the window, and then install a fixed window the size of the transom directly above the single hung with ganging enabled for the bottom. This should give you the desired look.
HTH,
Daniel
So that worked good but what happens with schedule know is that i get two columns showing main window Quantity 1 and than another column showing transom Quantity 1
Is there a way to show it full window as one window
is there anywhere i can buy or download this window (W DOUBLE HUNG2 SE9 WITH TRANSOM)
Thanks
TomWaltz
That's the problem with ganging windows. You have 6 or 8 windows trying to act as one, and the schedule is completely borked.
Tom Waltz
so is there a solution to my problem
TomWaltz
As far as I know, you can get the model to look right pretty easily by ganging windows.
The only way I can think of to get the schedule to be right would be to combine the two windows into one window object, which is not a form of hell I would wish on anyone.
Tom Waltz
Stress Co_
Use the (W Double Hung AwnU SE9)?
Marc Corney, Architect
Red Canoe Architecture, P. A.
well "W Double Hung AwnU SE9" is the best option for my windows but i would need double and triple windows with transom
THANKS
Stress Co_
There's always this:
http://www.cadimagetools.com/home.php?page=products&PHPSESSID=834c48a4654ea3c9d7dbd08071c81dbf
but it has it's own learning curve.
TomWaltz
I think it behaves differently in schedules than GS windows as well, so it could not be used in combination with them (though I could be wrong)
Tom Waltz
