Window and door building materials
Morning,
Is there a way to allocate different building materials to various elements within a window and door, eg Timber sash within an aluminium frame?
Also, is there a way to make the lines show up between a window/door sash and its frame as shown in the section attached?
Cheers
That would all depend on what doors you are using.
I'm using the hinged door 20, but it seems to be the same for all archicad library 20 doors and windows.
Can you suggest a way around this with the standard archicad library? I'm not interested in CAD image library, they are way too expensive for my purposes.
